I am installing a smart thermostat but I found the old thermostat has the green and red wires both running to the g terminal. When installing the new thermostat I will be removing the jumper wire between RC & RH. I do not have a heat pump ac unit only I live in south FL.
    I'm voting to close this question as off-topic because there was no answerable question asked. – isherwood Apr 7 '19 at 21:59
If you look very closely you'll see the red wire is on R and the green wire is on G. It just looks like the red and green are tied together on G.
  • Oh now I see that ! Wow it’s funny the older you get the more depth perception changes I guess that’s why I’m always peeing on my shoes ! THANKS FOR THE HELP ! – Adrian Lusardi Apr 7 '19 at 21:07
  • No problem! I just noticed the little copper ends sticking out. – Joe Fala Apr 7 '19 at 21:20
