There is a 50 mm thick wall which separates my balcony from the neighbors one. The damage done accidentally by my neighbor, show structure similar to drywall
Wall structure
I was thinking about mounting an IKEA ALGOT using:
Ideally I'd like to support up to 15 kilograms per shelf giving ~ 45 kg in total.
Now, wall uprights are mounted using 4 bolts. Since I cannot simply drill through the wall and use proper drywall anchors, I was thinking about something like 30 mm Fischer Duo Power plastic fixings (according to specs it should support at least 6 kg / bolt), but I have serious doubts if it can hold the load.
I'd be grateful for any insights / suggestions.
  • Do not know what " 30 mm Fischer Duo Power " is. – Alaska Man Apr 6 '19 at 17:47
  • @Alaskaman Thanks for pointing this out. I've edited the question. – user99170 Apr 6 '19 at 18:47
