There is an anomalous door sweep/pad (I'm not really sure what it is honestly) in the door track leading from our house to the garage. (I would call it the garage door, but this might lead to confusion)
It recently cracked from nearly 23 years of use and needs to be replaced soon.
What is it and how can I replace it? Images below: Sweep 0 Sweep 1
  • Sweeps go on the door, thresholds go on the floor. So threshold is what you need to replace a part of. – JPhi1618 Apr 5 '19 at 19:40
Some threshold cover strips are replaceable.
Try to gently pry up on it with a flat bar or putty knife, usually they are pressed into a groove, then take it to you local hardware store and look in the door threshold area to see if you can get a match. If you know the manufacturer of the door you may be able to contact them and see about a replacement.
Even it you can not replace it, it is not a big deal to have it missing, you can get a door sweep and attach it to the door to cover the gap. You can get the kind, like this, as it can be adjusted down. It appears your door has similar fins that are missing pieces.
