We have just had this wallpaper fitted by a professional. It’s on new plaster, which was sealed with a wash coat of emulsion and allowed plenty of time to dry. The staining has only appeared down one and a half seams but is really obvious. There is no wallpaper paste on the top of the paper as it was really well washed down, and the texture of the wallpaper when you rub your hand over is smooth - not sure what’s up! Has anyone experienced anything like this before? (The stains are on the right hand seam and half way up the left hand one!)
1One thing that is not apparent in your question is if this staining was there right away or if it was some time after installation that it appeared? If after, how long of a time? – Michael Karas♦ Apr 1 '19 at 11:31
Was there anything done to the wall in those 2 areas before paper was hung? Sometimes a reaction occurs with patching compounds that can discolor the paper. Also how long has the paper dried as of this photo? Blotchiness sometimes goes away with complete drying. Is the paper a vinyl coated wallpaper? Occasionally manufacturer defects occur where vinylcoating skips and the paper is vulnerable to absorbing paste residue in those spots. – Kris Apr 1 '19 at 12:20
The staining started appearing once the paper had dried. If anything, over the weekend it’s got worse....there was no staining at all when it went up! – Caroline Lawrence Apr 1 '19 at 17:39
Since you stated in your comment that it looked fine at first but developed these stains after drying I think there is some chemical reaction that occurred in those spots.
Plaster can have hot spots that need to be neutralized. I had a job where every area that was fixed with plaster was hot. After installing commercial vinyl a reaction between the adhesive and plaster began. In 24-48 hours the hot spots were blistering the vinyl off the wall.
If you are only seeing staining at 2 seams it may be that those seams were not adhering and the installer opened them back up and brushed in some premixed vinyl adhesive that caused staining. Some wallpapers can not tolerate vinyl adhesive and a bleed through will occur. Since this is a mural I would suspect it is made of thin delicate paper and you should carefully read the instruction sheet to be sure all preparation steps were taken and if it cautions against using certain types of adhesive.
It looks to me like the problem was caused during installation. You could guess that this is some other source of moisture, but it wouldn't travel that far from the seam, and if it's coming through the paper then it wouldn't tend to happen at the seams. I'd get the pro back, point out the problem, and see what they say.
