I have a machine screw from the hardware on an old desk that needs to be replaced (the knob it goes with is slightly stripped so it needs a longer screw to catch when mounted), but it's a really weird size. The outer thread diameter is 3.7mm, and there are somewhere between 30 and 32 threads per inch (it's 1" long but last mm or so of the shaft is missing threads). This doesn't match any standard metric or US size (it's between #6 and #8 and as far as I'm aware there's no #7).
photo of screw measured in caliper
    It's halfway between 6 and 8 and halfway between 3.5 and 4.0. Did you properly "zero" the caliper before taking this measurement? Apr 1, 2019 at 0:46
  • Yes. And I've been to hardware stores looking for something matching, and couldn't find anything, so I don't think it's a measurement error. Apr 1, 2019 at 1:01
  • Well then, all that data corresponds. Have you tried McMaster-Carr, Grainger and Fastenal? Can you lay it against a ruler and take a zoom photo of that from at least 3' away (to minimize parallax) so we can get a definitive thread count? Putting it on a desktop scanner would also work if the scanner has any depth of field... Apr 1, 2019 at 1:05
  • It's darn close to 9/64" Not a common size. A bit of mis-measure would give you 8/64" or 1/8". That's common in the US. Apr 1, 2019 at 2:52
  • I think your best option may be to re-thread the knob to take a more normal size of screw (something like M4). Apr 1, 2019 at 2:59
The closest thing I found to a match looking up various thread sizes with a 0.1875 inch British standard cycle, but even if that is what it is then I suspect you will find it extremely difficult to actually buy.
  • 3.7 mm is .145 inch so the .1875 would be way to large.
    May 3, 2019 at 19:29
According to Wikipedia,
The number series of machine screws once included more odd numbers and went up to #16 or more. Standardization efforts in the late 19th and the early part of the 20th century reduced the range of sizes considerably. Now, it is less common to see machine screws larger than #14, or odd number sizes other than #1, #3 and #5.
Applying the formula for the "#N" sizes, #7 would be 3.8354 mm, which is well within the tolerance of, and off in the same direction as, what I usually measure for thread outer diameters with my cheap caliper. Since both #6 and #8 are 32 TPI for coarse thread, #7 would be too. So I'm pretty sure this is actually a #7-32.
Prior to finding that, I actually did 3D print a 3.8 mm 32 TPI replacement, and it works.
printed replacement beside original screw
