I'm preparing to lay tile in my new bathroom and I picked up the cement board but when I got home I realized I bought quarter inch instead of half inch thick sheets. The Hardibacker website says that you can use quarter inch but a lot of websites that I've looked at recommends half inch for the walls. Has anybody use quarter inch cement board for shower walls with large tile with good results? another question I have is what is the preferred method for laying tile on concrete slab floor? Should I use cement board or the rubber mat uncoupling style? Any experiences are appreciated
1/4" hardibacker alone is an unsuitable substrate for shower wall tile. If it were attached to properly waterproofed drywall, plywood, or plaster it would be fine. Think about it, one wayward elbow, knee, or hip bump and you may get flexion which would cause the grout (or tile) to crack.
It depends on the application. Concrete is porous, so for water applications (like a shower floor) there are specific established methods for waterproofing, sloping, and draining.
For dry area applications, concrete is the perfect tile substrate as long as it is clean and dry. Just apply thinset mortar using the application technique recommended by the mortar (and/or tile) manufacturer.
  • Cool, so would I still need plywood if I exchanged the quarter inch for half inch Hardy board? I just built a standard shower enclosure 60" long with 2x4s.
    – BigLake
    Commented Apr 1, 2019 at 9:25
  • Nope, no plywood needed behind 1/2"! I always staple waterproof craft paper to the studs, arrayed horizontally starting at the bottom with successive runs overlapping the run below and with the bottom (first run) lapping out under the tileboard into the pan (picture if water were to penetrate and how the paper would allow that water to run down the paper and out into the pan). Tileboard goes over that. Commented Apr 5, 2019 at 17:23
If you're looking for the proper way to tile a shower, including pre-slope, pan, etc. take a look at this guy's YouTube channel. It made me realize that building a tile shower takes a little more than just throwing up some Hardibacker and tile.
https://www.youtube.com/user/saldibs/playlists
  • That's funny you posted that,I was actually watching his channel about the tiling fails that led me to asking about the cement board. These guys are good.
    – BigLake
    Commented Apr 2, 2019 at 23:07
I install 1/4" HB all the time right on top of 1/4" drywall. Easiest way to do a tub surround.
