Is it possible for the tank water to bypass the bowl and straight to the drain? Would this mean I need a new toilet?
The toilet was running and I have been trying to fix the flush valve.
Mansfiled toilet.
Mansfiled toilet.
It's most likely a bad flap, probably not seating correctly on the bottom of your tank. this can cause the water to constantly flow straight into your bowl and as the bowl fills up it will automatically drain. Try cleaning it or replacing it.
No water can not bypass bowl. The bowl is connect to the drain. The cistern is connect to the water supply. The only way to get to the drain is through the bowl.
