These are the last bulbs in the house that I have not been able to change over to LED.
You might be thinking to yourself, they only turn on for 1 minute, what is the big deal. I've started to notice if both bulbs are plugged in and you run the opener too many times, the opener starts to over heat. No bulbs, and the opener keeps going like the energizer bunny.
enter image description here enter image description here enter image description here
I've tried almost every single LED bulb that I've been able to get my hands. And the hole is designed for only this type of bulb unfortunately.
Any Suggestions?
The plate where the bulbs sit is not screwed in, it's welded into the opener. I thought about making the hole bigger, but worry about damaging the opener.
  • Are you really saying that two 60W bulbs cause this unit to overheat? – Solar Mike Mar 31 '19 at 19:58
  • Yea that's what i'm saying. Is it 100% true? Maybe not. But the fact of the matter is, I want to put leds in my garage opener. – Sickest Mar 31 '19 at 20:03
  • I personally would consider opening the unit and re-positioning the bulb holders... do make sure you have isolated the unit before attempting any work... – Solar Mike Mar 31 '19 at 20:08
    you can get LED "piano" bulbs; long tubular bulbs no wider than the screw base. – dandavis Apr 2 '19 at 20:58
    be careful with using LED bulbs for garage door openers. Something about the light impacts how the wireless remotes function. You can google it and find out more about it. I put in LEDs in mine and started having random problems with the remotes not working properly. I worked with Chamberlain and it was determined the LEDs were causing the issue. Put back regular bulbs and no issues. – user99045 Apr 3 '19 at 19:04
I do think the opener is named incorrectly - it should be Ambass-a-door. But that doesn't affect the solution:
Get an extender
Leviton Medium Base Socket Extender
IMHO, $2.74 isn't much compared to the hassle of cutting a hole in sheet metal and risking ruining a functional garage opener.
    That doesn't look like it would fit either. The narrow part of the housing is too short. – isherwood Apr 3 '19 at 19:36
  • Might work. If his opener is like mine, however, it has a frosted plastic cover which wont fit over the bulb if it sticks out further. – Sherwood Botsford Apr 3 '19 at 20:58
An alternative to using a hole saw is to use a nibbler. The shards of metal are larger.and the metal falls on YOUR side of of the hole.
Or use a tin snip and snip a quarter inch out from the hole every quarter inch, producing a set of tabs that can be bent in. This produces no metal that can short things out. This doesn't work if the hole has a rolled edge unless you have strong wrists.
Do push them in, however. The sides of the bulb will push them in for you, but might make removing the bulb difficult.
I am assuming they do not fit because the leds flare out a bit more at the bottom and the hole in the with metal panel is not allowing them to go in all the way.
Make the hole bigger. Make a jig out of scrap wood with a holes bigger, Use a hole saw to make the jig, clamp the jig on the unit and use the same hole saw in the jig to cut the metal panel.
Turn off the breaker to the unit and go slow, careful not to plung to deep when you get through the metal.
    Not a bad idea, but pretty risky flinging metal shavings around near a circuit board. – isherwood Apr 3 '19 at 19:38
I would just remove one of the 60 W bulbs and see how it performs. If you need both sides illumnated, try two 40 W bulbs. Any greater intervention would not be worth the trouble, for me anyway.
Just unscrew this nut and remove the white backer plate, leave it off or cut the hole bigger if you want and replace it.
