I have a furnace equipped with 1/2" pipe for gas supply. The protruding pipe is male npt. The 10KBtu wall furnace expects 11-13" w.c. Are there solutions out there that go from a 20lb propane tank on one end to the 1/2" npt on the other? I'll just use a 3/8" adaptor to 1/2" if needed, since it seems like everything out there is 3/8".
I want to have 10' of hose or so and a twin-stage regulator to 11" w.c.
