I have a 1200W smoker which I currently hook up to an outdoor outlet. The outlet runs on about 75' of 12 gauge wire from a 20A breaker. There is nothing else on that circuit. I am moving the outlet to a new permanent location and will be using solid copper wire for the extension.
I want to add my smoker in a permanent spot about 45' away from the outlet. So basically I am moving the outlet, so that will be a total of 120' wire length.
Will voltage drop be an issue for me if I extend with 12 gauge? If yes, will it be ok to make the 45' extension with 10 gauge to keep the voltage drop down?
