I'm trying to figure out the right pipe to buy for a direct vent wall furnace. The instructions show 3/8 inch npt, and also say that the gas inlet is 1/2 inch. When I measure the gas inlet it appears to be about 3/4 inch. I'm attaching pictures of the instructions and the gas Inlet to show what I mean. It's an Empire Heating Systems furnace, DV210SGXLP-1.
I could use some explanation of what the numbers mean.
Generally, the bigger the better. Assuming you already have gas, you should match what you have already installed. The size shown is the minimum for each of the 2 gases, Propane vs Natural Gas. You can use a pipe nipple/reducer to reduce the size of the valve inlet as needed. As for the other numbers, BTU is the heating factor (British Thermal Unit), higher number means it will heat a larger space, or a smaller one faster. The dimensions are used for the place you plan to install the furnace. Your gas valve is 1/2"ID(Inside Diameter), your measurement is 3/4"OD(Outside Diameter). So a 1/2" ID NPT(National Pipe Thread) is what you need at the valve, however, up to the valve you can plumb 3/4"ID. If you are doing a new install from the meter, best to go with the 3/4" in case you plan to upgrade in the future or add additional gas appliances.
| improve this answer | |
  • Excellent, thank you. It's a new install, so I don't have any existing pipe to compare with. – Don Branson Mar 24 '19 at 22:27
