My toilet tank was leaking rust and water, so I replaced the three bolts at the bottom of the tank.
But when I replaced the supply line/tube, the new supply line/tube sprays water from below the coupling nut. See the picture.
How do I correctly install the supply tube?
Thank you in advance.
