I had been planning to lay standard clay pavers over a sand bed in my front walk. I had planned for a standard size of 4 x 8 and maybe 2 3/4 inches tall. However, the brick that I like comes in this size: 2-1/4 x 3-5/8 x 7-5/8. I first thought that this was a smaller size specifically meant to be installed with a concrete foundation and mortar base. I would think that a shorter height makes it more susceptible to rotating if laid in sand, but this is not a problem when embedded in mortar. And they are skinnier to fit into a standard brick size when surrounded by mortar.
Or, it doesn't matter. The brick manufacturers picked one particular size to sell, and its up to the installer to decide sand or mortar bedding.
Can I still use the smaller bricks with a sand bed?
You can use the smaller brick with no stability problems. The only issue you will have is if you chose a "basket weave" pattern when the brick are laid tight. The width of 2 bricks will not add up to the length of a brick side since these are sized with a mortar joint in mind.
If you use a stack bond, running bond or even herringbone, you can lay them tight with no issues at all.
A shorter height makes them more resistant to rotating, but the narrower width makes them more prone. Consider a log on a pond: It's round. Rotates easily. Plank doesn't. More plank like, more stable. Closer to round, less stable.
A building brick is exposed on it's edge, so you want to increase the height faster. Standard brick is easy to hold in one hand. A really large block makes for interesting problems for openings. If you build with the common ~8 x 8 x 16" concrete block, it affects your choice of windows.
The main function of thickness is to not break under the proposed load. Here in Alberta, concrete block pavers are often used for driveways, so it has to be able to withstand car weights. In general, the thinner and larger the block you use, the more solid your sand bed needs to be. An unsupported patch the diameter of the thickness of the block I don't think is a big deal. It has the strength to bridge that. As the unsupported patch gets larger, it will take less of an impact or load to cause the block to fail.
Blocks have a wide variety in thickness.
Patio blocks -- those 2 foot x 2 foot (sometimes 30" for the 2nd dimension) are usually only 1.5" thick. They are frequently bedded on sand, or sometimes on road crush. I don't see them used for driveways.
From the manufacturer's point of view they are balancing the following:
Thicker blocks:
  • more material to make = more equipment, more money.
  • may be able to use leaner cement ratio, which is cheaper.
  • more expensive to ship.
  • gives more substantial feel to final customer.
Larger blocks:
  • Edge finishing more difficult. Curves difficult, as there are fewer joints to absorb the variance.
  • each block more difficult to move and place.
  • final customer has to make better bed for placement.
Smaller blocks:
  • Takes more blocks. Placing time below a certain size is per block.
  • Fancy shapes easier.
  • less stable for a given thickness.
The size around 4x8 is easy to place one handed, so once you have a bed, laying them is fast.
Locally I see pavers that are about 4x8 (your size) about 8x8 (requires two hands to set.) 8x16 (2 hands, but more pattern possibilities) 24x24 patio blocks (takes two people to place easily) 24x30 (ditto) I've also seen hexagonal ones about 10" across, and a triangular one with circular arc edges to lock together.
Locally I see colours being natural (grey-white) dusty pink, and dark grey. I suspect that they are coloured with iron oxide and charcoal black, both being cheap mineral pigments.
Whatever you go with, put an additional patch of them somewhere -- base for a compost bin, splash point for roof runoff, whatever. This way if down the road, you break one, you will have a spare. These things go in fads. Just try to find a matching block from a walk that was done 30 years ago.
    Your plank and log metaphor about rotation makes sense. I thought taller bricks on each side would provide more support against rotation. Mar 23, 2019 at 18:12
  • You have a point. Hadn't considered that. Now I'm not sure. Mar 24, 2019 at 0:18
    The most authoritative source I have found The Brick Industry Association's linkTechnical Article #14. that says: bold Sand-set pavers are the most cost-effective method of constructing a pavement made with clay pavers. The system relies upon developing interlock in the paving course, which is generated by friction between the pavers and the jointing sand. This enables the pavers to function as part of the structural pavement system. Mar 24, 2019 at 22:02
