I'm looking to make a desk/shelf unit like in the image below. For the vertical pieces of wood (to make the two A-frames) what dimension of wood is advisable?
I would like it to appear skinny rather than chunky so considering using 18 x 65mm pine. Does this look suitable?
If using this 18mm x 65mm wood how could I attach the horizontal supports between the A-frame vertical sections? To use screws from each end the screws would need to be 65mm (through vertical sections) then ?25mm into horizontal support. This would require very long screws and a long drill bit. Does this sound reasonable? Is there a better way to attach the supports?
Thank you
