I have a autistic son who tends to sleep walk. I have found him a few times sound asleep in the bathtub with the shower running. I'm looking for some type of timer that limits the hours a shower can be used, like say between midnight and 5:30am.
    Would he be able to sleep in the shower if it was a cold shower? Mar 21 '19 at 22:27
  • Australia has shower timers that limit the flow of water to 3 minutes (from Australians who told me...)
    – Solar Mike
    Mar 22 '19 at 8:56
    Non-concussive shower valves are used in sports centres etc. They give a few minutes' showering after pushed, then shut off, and work under water pressure. Any commercial plumber should have them
    – Owain
    Mar 22 '19 at 13:06
  • Another option could be installing a valve that's too high for him to reach.
    – JPhi1618
    Mar 22 '19 at 14:51
  • Depending on the layout of your bathroom, you might be able to install shutoff valves for the shower supply lines, and secure them behind a locking panel door. Then you could effectively disable the shower before going to bed, without affecting the sink and toilet. That would be cheaper and easier than any sort of electronic timer solution.
    – Jerrad
    Mar 22 '19 at 15:20
You could plumb a 12 volt DC electric solenoid water valve on the hot and another one on the cold water line to the shower. Take a 120 volt AC to 12 volt DC transformer and wire it to them. Then put the 12 volt transformer on a 120 volt timer and have it power the solenoids when he is allowed to use it.
It's doable but it would likely be a pretty big job. If you fit the hot and cold supply lines with electric actuators - devices that open and shut valves -
valve actuator
and control those actuators with a timer
timer
you could turn the water on and off on a schedule set on the timer.
This is simple enough but not easy, and there are a number of caveats that come to mind.
The devices involved are not small, certainly not stuff you can stuff inside the wall - depending how your plumbing runs, you may have to do extensive work to reroute the supply for the shower through a location where you can install these devices.
You'd need robust actuators - you'd have to use something with a duty cycle that will tolerate daily use, not something designed for occasional use or shutoff when a leak is detected.
You would want to make sure your water heater's temperature is set low enough that there is no chance of scalding with the hot water all the way on, and no cold water. (This is a good idea even independent of this project.) It's possible that the system could malfunction and leave the hot supply open and the cold supply shut, and someone gets full blast hot water in the shower. You could make the system more reliable with redundant actuators on the hot supply, etc., but you can never make anything 100% reliable.
If you are just trying to schedule when the water will run, go to an irrigation supply store, and get a simple 1 zone water valve kit. (You can also do this from Home Depot stuff. You need a valve, and a 1 station timer, and the handfull of adapters to go from (usually) 3/4" female ports on the valve to your household water system.
Done this way, it would only shut off one line. You may want to use a valve on both the hot water and cold water lines to the shower. Check with the specs on the zone controller as to whether it can control more than one valve on a single zone output. Usually not a problem.
Edit: Any system that can leave the hot water running, but not the cold is dangerous. Valves can fail: stuck on or stuck off. Interrupt the hot water only. full cold water is unlikely to be harmful.
Valves run 15-30 bucks each. a 1 station controller is between 50 and 100. Since you don't need rain sensors, remote programming, etc, a cheaper controller should work.
Do this in a way that it is easier to undo it. The next house owner probably won't need this feature.
  • According to Orbit's web site, their valves are intended for cold water use only, and not rated for hot water applictions.
    – Mark
    Mar 23 '19 at 2:18
  • I'd be worried about any solution that turned off hot and cold water separately -- if the cold water solenoid failed for any reason, then the shower would only be producing hot water, which could be a safety hazard.
    – Johnny
    Jun 5 '19 at 22:22
  • Good point. @Johnny . I have edited my answer to say interrupt hot water only. Jun 6 '19 at 12:32
You might want to consider some form of child safety lock instead; either on the bathroom door, or on the shower if it has a door as opposed to a curtain. (Obviously more difficult if your kid needs to use the bathroom in the middle of the night, and you don't want him to wake you.) I don't know your exact circumstances, but in general securing access to the room might be easier than securing access to water. For example, the answers to Where can I find a Time Restricted Keypad Lock? may prove useful.
You can use solenoid valves. They are a much less expensive option then a valve actuator. Valve actuators are a good option but a little bit more expensive and potentially more complicated to install. Solenoid valves are available in many different voltages, sizes, flow rates and suitable for many different applications.
  • It looks like you might have intended to include a photograph in this post. Any chance you can remember what it was, or come up with something similar? Thanks!
    – Niall C.
    Feb 28 at 1:14
