Hi I am hoping someone can help me - I turned my water supply off and replaced two ballcocks - one for heating and one on my main tank - drained all water out of the system - turned supply back on water flowed perfect. I have 2 electrical shower both off the mains water supply. One shower works as expected - however my second one doesnt work in fact there is not water supply getting to it at all and doesnt work.
Any suggestions would be appreciated
    I'm not sure what an electrical shower is, but it sounds terrifying. – JPhi1618 Mar 20 at 14:46
  • @JPhi1618 It sounds like one of the "point of use" showers - fed with cold water and has an in-built heater (needs a large electrical supply, usually on its own breaker)... quite common in some markets. – Solar Mike Mar 20 at 17:26
  • This sounds like you have an air-lock somewhere - turning taps on and off may cause the water to push through... Have the shower tap open... – Solar Mike Mar 20 at 17:28
    @jphi it means an on-demand heater dedicated to the shower. – Harper Mar 20 at 21:01
