I live in a 1980s mobile home with light switches and breakers as in the picture. If the switch is arcing or if the switch is held between on/off for a few seconds can this damage the breaker? The switch is a self contained type.
  • The arcing would be at the switch. I don't see how it could damage the breaker, but it sure could damage the switch. – manassehkatz-Moving 2 Codidact Mar 20 '19 at 3:04
Arcing is not a good thing for the switch but it won't damage a standard circuit breaker. If the switch contacts are held at a point where they arc the arc starts damaging the contacts. With a older possibly Mercury switch where there is a glass tube with Mercury the arcing if held to the point the mercury vaporizes I have seen the glass tube fracture so a new switch was needed.
| improve this answer | |
