I'm in the planning stages of a new workshop/shed build. I plan to run a 60A ciruit from the main panel in the house to a subpanel in the shed.
I recently picked up a used Challenger QM322200 200A breaker panel with about a dozen circuit breakers for a song. Can I use this panel as is, with the stock 200A main breaker as a master shut-off? (I'd relabel the panel as 60A).
If no, where can I find a 60A main breaker to swap into the panel?
Thanks for your help.
This is the label on the panel:
