So I'm about to tile my bathroom floor but the toilet flange broke and can't get it out I tried with a chisel and hammer but I think I got the pipe to so how can I fix this situation I got here
"I think I got the pipe to" Are you certain you cracked the pipe below?– Jerry_ContraryMar 18, 2019 at 13:04
Not sure if I did or not I don't think I did– Anthony TomasettiMar 18, 2019 at 13:06
I'm going to say yes– Anthony TomasettiMar 18, 2019 at 13:07
So expose the pipe properly and replace the damaged section.– Solar MikeMar 18, 2019 at 13:09
By exposing the pipe you mean cut some of the cement around it?– Anthony TomasettiMar 18, 2019 at 13:10
1 Answer
Assuming the pipe below the concrete is OK, you can buy a replacement flange that is designed to sit inside the pipe and grip the pipe in such as way as to secure the toilet
If the pipe below the concrete is damaged, you'll need to excavate the concrete and replace the entire damaged section. The good news there is you can install a new flange directly connected to the pipe then.
