For those who are experienced with the Sonoff devices, I need to check the temperature in my living room using a Sonoff thermostat TH10, and when the temperature is above a chosen threshold, I would like to stop the water pumps which are in a different room, using a "slave" Sonoff basic device, remotely controlled by the TH10.
Is such a configuration possible?
