At night, my windows reflect the room and obscure the outside view. Is there a way to reduce the reflectiveness of the windows?
  • Window tinting. There are a few products that do this. Reduce glare is what you need. – Jeff Cates Mar 17 '19 at 19:45
    Move the lights so they don't reflect where you're sitting. – Carl Witthoft Mar 17 '19 at 20:20
  • A curtain or shade will do the trick. – Steve Wellens Aug 10 '20 at 14:39
  • Did you ever get this resolved? If so, please give a check-mark to the answer or write up your own answer explaining what you did to get it fixed and give yourself a check mark. That will help others with this kind of problem know that this has a resolution and is a good place to look for their answer. – FreeMan Aug 10 '20 at 18:28
There are things such as anti-reflective/anti-glare film that many storefronts, counter displays use to increase see through. It's not often used privately though.
One example is this: https://www.ssidisplays.com/anti-glare-film-window-displays/
I'd try asking somewhere they sell glass for windows-panes or whole windows.
Just remember, it's very limited how much it would work with a lighted room, at night, looking out into the dark. Try lowering the light intensity in the room a bit as well, possibly. That could be done with a bulb of lower wattage.
