I've seen a few posts on how to wire a single post/column for lighting outdoor but I can't find anything that relates to multiple posts/columns.
I have 7 posts/columns outdoor and I'd like to add lighting at the top of each post. These posts/columns will be used with a fence (in case you are trying to visualize this).
So far this is what I understand I need to do in a nutshell:
- Dig a trench of 18" and bury wiring with PVC piping
- Use existing outdoor GFCI and extend your wiring from that outlet as long as you are not overloading the circuit
- Use a wiring hub that runs power from the outlet being used to the main hub input and then have separate outs from the same hub running to each lamp that will go to each post/column
Here is where I need some guidance:
- What is a good hub to use outdoor? When searching online, I only find extension cords hubs. This isn't what I need. Does it have a different/formal name?
- My run from the outlet at the house to the hub by the posts/columns would be about 60 feet. If I position the hub midpoint of all posts/columns, I have about 40 feet each way (left or right) to the furthest point to supply cable to each lamp on each post/column. Do I need some sort of amplifier so that I don't experience voltage drop? If so, which one and how do I introduce this?
- I've read that looping or daisy chaining just makes it more complex trying to maintain adequate voltage (evenly) on all post so a hub is recommended. Is this correct?
I have a basic understanding of electrical and wiring. I've done some smaller projects at home so tackling this isn't a concern. I'd just like to know what are the right components I need to ensure this is done correctly
