Trying to remove a broken setscrew on part of my stove. Top photo is the current state, the second photo is another part showing an intact screw for comparison.
I already tried to drill out the screw to use an easy-out but the bit wandered, cutting into the wall of the hole, perhaps 1/16th" deep. Oops.
Wondering if anyone has a suggestion how to recover this situation. Perhaps a good blow with a punch into the true center of the screw could still work, but thought I should get advice before making it worse!
I'm open to re-tapping it for a larger screw if that will work / is necessary.
It seems possible to replace this component if necessary so all is not lost if the screw can't be removed. Although disassembly of the entire apparatus would be nice to avoid. Some of it seems possibly pressed together (?).
Thanks!
