I have a small closet under my stairs that doesn't have a light switch. I've been wanting to tie into a circuit from somewhere to wire up a light. While crawling around under there I found a (junction?) box with a single 14 ga cable running into it. The box is not protruding on the other side of the wall so it's not an outlet or a switch. when I wiggled the wire does not feel like it is connected to anything inside. Appears to be 14/2 Romex. Before I open it up and waste any time, is this something I could tie a light switch to? I I wouldn't imagine that someone would just leave an open-ended circuit in a box under a staircase, the house was built in 1992. Having an issue posting a picture right now, will try again shortly. Any insight would be great.
1Does it not have a light either? Is there a receptacle nearby? Or does it have a "pull chain" fixture? – ThreePhaseEel Mar 17 '19 at 14:04
1Did you test the conductors to see if the circuit is hot? – Retired Master Electrician Mar 17 '19 at 14:06
Yes. And nothing, was just an empty box with a wire cutoff inside it. – BigLake Mar 17 '19 at 17:31
Add a comment
Ok got it all set. It was in fact a dead end wire. It belongs to the circuit powering the bedroom on the other side of the wall. It was just a box with it's open end facing the back side of the sheetrock. I wired it up to my light and it works. Does anyone find it odd that this was just sitting in there like this?
3I suspect the box is there specifically to support a light in that location. It was specced at build time, because that is when that is easy, and then left for the homeowner to finish as s/he pleases. Which is good, because at the time they would have installed a cheap Edison base and an incandescent, and I have personally witnessed a fire started by one of those in an under-stair storage space... whereas you can now choose cool running bulbless LED fixtures. – Harper - Reinstate Monica Mar 17 '19 at 15:31
1I have seen similar minus the fire but LED's are the way to go. Should be an answer. – Ed Beal Mar 17 '19 at 16:06
Harper, how did the fire start? I did install a single light fixture in a light box with a switch. – BigLake Mar 17 '19 at 21:07
@BigLake old incandescent bulbs get hot when left on for any amount of time. In an enclosed space with flammables nearby it's just a matter of time. – ratchet freak Mar 18 '19 at 11:46
