Building code calls for 3" x .131 nails for wall framing. I wanted to use ring shank which have a better hold, but I can't seem to find RS in .131. Whenever we go to RS, the diameter drops to .120. You can get .131 diameter nails in smooth shank though.
So unless I'm mistaken, it looks like you can get RS .120 OR smooth .131, but not RS .131. (These are 21 degree gun nails).
I want to do a quality job, and the inspector doesn't care which kinds of mails I use.
Given the choice, am I better off with smooth shank .131 or ring-shank .120 nails? The rings would probably hold better, but will the reduced diameter cause other issues?
Clarification: The issue that I'm running into is that I can't find the nails that code calls for locally (and I mean at the lumber yards that supply real framers, not box stores).
My code wants 3"x.131, and the lumber yards have RS .120. When I try to get what the IRC prescribes, I get: "that's what everyone uses here" and "they don't even check nails so don't worry about it".
So the problem is, should I be using what the code book specifies (which I would have to special order and is extremely hard to find) or use what all the supply houses in my area are selling to all of the framers for wall framing because that's what they actually use around here?
There are no high wind speed or seismic considerations.
