Planning to run 6 lights from a sub panel around my pool. 20 Amp GFI breaker in-place. Planning to run THWN 12 gauge wire in plastic conduit for the lights (pole lights) with at least 2 switches. Want to add an outlet at base of each pole for added electrical options (low amp/watt) decorative rope lights or Christmas lights. Unsure of how to add the receptacles. Also, may want to have a separate switch for the receptacles. Any suggestions are appreciated.
  • DO the poles have any provision for a receptacle? Many do... – Harper Mar 15 at 16:40
  • This seems like a pretty basic wiring scenario, so I'm unsure what you question is. What specifically are you having an issue with? – JPhi1618 Mar 15 at 18:35
  • What make and model are the poles you are looking at, or have you not picked your poles out yet? – ThreePhaseEel Mar 16 at 1:38
  • I have the poles. Got them at a restore. There is no receptacle on them. I would need to probably mount the recpticles close to the pokes. Currently the poles have concrete on them with conduit for woofing. I don’t want to remove the concrete so will just just bury them with additional fresh concrete. – Misto Mar 16 at 3:07
