I have a new tub being installed that takes a deck mounted faucet. I found a faucet I like which is a two handle, 3-hole type. However, it would be nice to have a wand mounted on the deck as well. Is it possible to add it? How do I control the water temperature on the wand if it is not integrated with the faucet?
  • I think the key is going to be finding a faucet that supports one. – JPhi1618 Mar 14 '19 at 17:43
In order to have an integrated wand attachment you have to have an integrated wand setup if you only have three holes there are options available. If you're set on the fixture that you found it may provide much trouble to add a wand attachment. Try looking up the part number for the one that you have and see if there's an attachment available for it. Retrofitting a third-party wand attachment depends highly on the configuration of the faucet that you have in mind.
Here's an example of a 3 hole setup enter image description here from The Home Depot
| improve this answer | |
  • You can usually drill another hole if you happened to find a 3 hole faucet + wand variant. The existing holes are normally reinforced, so the additional hole should be used for the wand which shouldn't need any additional strength. – JPhi1618 Mar 14 '19 at 17:49
