I am installing a thermal expansion tank and the maker (Watts) recommends installing a service check valve between the tank and the pipe.
While I understand the convenience factor of the SCV, my concern is that I would be introducing another potential point of failure into the system by adding a service check valve. Is it advisable to do this?
Yes, it is good practice to fit an isolation valve.
This makes replacement of the expansion tank easy without draining the whole system.
This is also a practice followed for many components in a water system, as these valves are cheap & reliable, so putting them either side of a pump can save a lot of hassle when trying to bleed a system.
  • Hi, Mike. Sounds like a good answer, but would you mind adding a bit of context, or just a few more sentences of support? We don't usually like sentence-fragment answers. (Thanks.) Mar 13, 2019 at 15:15
