I'm interested in building a steel Quonset hut home in central Texas. I've done a fair amount of research on what's involved, but I'm stuck on insulation.
The IECC defines minimum insulation requirements for light-frame construction like wood & steel studs, but it's less clear (to me, at least) how those requirements translate to a unique structure like a Quonset hut, where the steel sheathing is the structure.
See the code here (mainly TABLE R402.1.2; I'm in Climate Zone 2):
https://codes.iccsafe.org/content/IECC2015/chapter-4-re-residential-energy-efficiency
With regard to minimum insulation requirements, how does the International Energy Conservation Code (IECC) apply to steel arch buildings like Quonset huts?
Specifically:
  • What constitutes a "wall" and a "ceiling" in a semicylindrical building? End walls are obviously walls, but is the entire remaining arched structure then a ceiling?
  • Which exact R-values am I targeting in which exact portions of the building?
  • Does anything from R402.2.6 Steel frame ceilings, walls and floors. apply here? A Quonset hut is steel but isn't exactly "framed," so I'm unsure.
A popular Quonset hut insulation approach seems to be 2" of closed-cell spray foam, which totals ~R13, which makes me curious if then the steel arch structure is considered a large "wall." Probably not a safe assumption, though, as these are often used for garages, which can often be uninsulated (i.e., don't have the same minimum R-value requirements as a home), and therefore this may just be done for comfort, not to satisfy any code.
    Since you are in central Texas you might want to give the people at the Monolithic Dome Institute a call and see if they can help. They make dome structures that are somewhat similar to what you're talking about and might have some input on requirements of non-standard buildings. – JPhi1618 Mar 13 '19 at 17:58
