My home has a poorly installed suspended ceiling in my basement using 2'x 4' tiles with many tiles sagging and not attractive. I am not a fan of suspended ceilings. Is there a better ceiling choice that I should consider instead? Or should I invest in replacement tiles to improve the appearance? Many of the tiles sag or are discolored. I suspect they were probably installed in the mid' 70's.
  • Welcome to Home Improvement! Unfortunately, any answer to this question will be a matter of opinion. Please take our tour so you'll know how better to contribute here. – Daniel Griscom Mar 12 '19 at 10:21
    Some pictures would make a lot of difference for this question. – Greg Nickoloff Mar 12 '19 at 12:10
Yes, there are several alternate ceilings that could be installed: 1) suspended ceiling with decorative panels, 2) gypsum board on suspended metal runners, 3) gypsum board applied directly to floor supports,
First, if the existing tiles have water stains (which turn brown) and sag, it could be due to a leak. You’ll need to find and fix the leak before installing a new ceiling.
1) There are many decorative suspended ceiling options. Here’s some options: https://www.decorativeceilingtiles.net/suspended-drop-ceiling-tiles/
Or: https://www.proceilingtiles.com/
2) Because your existing ceiling is suspended and you like a standard gypsum board ceiling (to match the rest of your house), you may need to suspended it on metal runners. Like this:
http://web.nwcb.org/CWT/External/WCPages/WCWebContent/WebContentPage.aspx?ContentID=98
3) The most common (and probably cheapest) is gypsum board applied directly to the bottom of the floor supports. However, if you have heating ducts, electrical wiring, etc. under the floor supports, then moving all that will be expensive.
  • Aren't there new types of panels for suspended ceilings which are stiffer and lighter weight? Replacing the panels would be by far the easiest and cheapest solution. – Jim Stewart Mar 12 '19 at 13:00
I know I'm giving you late reply to you but it will useful for you in the future as well. First you have to understand you suspended ceiling and why your tiles are getting discolored i.e you are not using good quality of tiles of might be a leakage at your ceiling. So for the best result you must have to replace that tiles with the latest good quality of tiles. Also you have to understand types of suspended ceiling you have like: Panels and Tiles, Hidden Grids, Stretch Ceiling and many more types. Here I m giving you a few sources that could be help you in the future, if you face any problems related to this.
Sources: YouTube Heronceiling Doityourself
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know how best to contribute here. – Daniel Griscom Dec 24 '19 at 11:12
