My overhead metal door is “wedging” when close to bottom but also is hitting a track mounting bolt when it is forced up from inside. When I push up from outside, it does not hit the bolt(s). I believe the door is too close to the side where it is hitting the track mounting bolts. How do I slide the door over?
    I wonder if the cables for the torsion spring have slipped or moved? Check the attachment of the cables to the door... carefully. – JPhi1618 Mar 11 '19 at 20:49
  • Hello, and welcome to Home Improvement. What kind of garage door is this? Could you post a picture of the inside of the door when it's down? – Daniel Griscom Mar 12 '19 at 0:11
