I just replaced a switch with an led compatible switch (lutron). It switches on two led lights. Currently i have one philips led bulb and one cree led bulb on the switch. I also figured out that the cree 65W bulb is not compatible with teh siwtch.
Now when i turn on the led switch, only one light stays on. If i take off any of the led light - the other one stays on. If i take off the philips, cree stays on and if i take off the cree then philips stays on.
Is it a problem of compatibility or i have not connected the switch properly? I think if i would not have connected it properly then one of the bulbs would never have turned on.
Should i put both bulbs to be cree or should i replace everything with the switch compatible led bulbs ?
