Suppose I have a continuous joist supported somewhere in the middle. For ease let's say it's a 24 foot continuous joist, and there's a bearer right in the middle at the 12 foot mark.
Here's a picture I found online.
Image found online
I know I should not notch or bore in the middle 1/3 of the joist. Does a bearer make this joist two spans per this image?
Can I notch between 0'-4', 8'-16', and 20'-24'?
Or 0'-8' and 16'-24'?
Answering my own question after a more thorough reading of the spec.
R502.8.1 Sawn lumber. Notches in solid lumber joists, rafters and beams shall not exceed one-sixth of the depth of the member, shall not be longer than one-third of the depth of the member and shall not be located in the middle one-third of the span.
And it includes this very helpful graphic:
So the answer is:
  • A bearer does make a continuous joist into two spans.
  • I can notch between 0'-4', 8'-16', and 20'-24'.
