When not running any warm water, and having my tap about half open, the cold water pulsates a bit. The stream moves forwards and backwards about half a centimeter. I'm assuming the pressure fluctuates.
When showering (thermostatic tap) I also hear that the water pressure fluctuates.
What could cause this, and how do I fix it?
There are a wide variety of reasons why this happens ranging from the water meter to air in the lines and water hammer. The easiest way to fix it is to install a cushion tank or expansion tank you have to make sure it's a potable water vision.
Here's an example of oneenter image description herewww.amazon.ca
They are relatively inexpensive but do require some plumbing to install.
