-1
I want to mount a piece of wood on 1 wrought iron bracket at the side of a framed window with the shelf running about 3 feet across the window and no bracket on the other side. How can I determine how much weight it will hold with only 1 bracket. I want to put plants on the shelf. (this is a picture window so I don't want the shelf do go across the entire window)
  • What is going to support the other side of the shelf? What is under the shelf (how bad will it be if the shelf falls)? – JPhi1618 Mar 7 '19 at 20:22
  • nothing will support the other side. The point of leverage will be the mounting of the board on the bracket. Can it work? – user98020 Mar 7 '19 at 20:51
    It's extremely unlikely that a shelf with one bracket will provide a favorable outcome. (Have you ever seen one?) It's hard to say knowing nothing about the bracket, though. – isherwood Mar 7 '19 at 21:10
    Maybe I'm not picturing this correctly, but I'm seeing a 3ft long shelf with a bracket on one side and the other side just hanging there? No, that's not going to work. – JPhi1618 Mar 7 '19 at 21:10
    You might as well ask how many clowns a unicycle can support. :P – isherwood Mar 7 '19 at 21:12
It's kind of a physics question but to point you in the right place
Torque = radius x force
Torque it the twisting at the anchor point
Radius is the center of mass So the further from your anchor the more torque
Force is lbf or just lbs will be fine for the application.
To find the centre of mass (radius) take your shelf and find the balance point. Probably the centre so 1.5'
Weigh it we'll say 10 lbs
Torque =1.5 feet x 10lbs So 15 foot pounds torque.
Now you add what you want to put on your shelf but keep in mind that center of mass changes the farther out you go.
And you need to cross reference your iron to see its capabilities.
| improve this answer | |
