I’m having problems with my Trane model Yc0060C3H0AA rooftop unit. My inducer motor comes on, my igniter lights up and I can smell the gas valve opening up but my burners will not light.
Serial # g081422350
Sign up to join this communityI’m having problems with my Trane model Yc0060C3H0AA rooftop unit. My inducer motor comes on, my igniter lights up and I can smell the gas valve opening up but my burners will not light.
Serial # g081422350
CHECK FOR GAS AND THAT IT IS GOING IN THE RIGHT PLACE
I would check the gas pressure and the orifices or venturi. If a bug got in the orifice closest to the igniter gas will flow to the other burners but may not ignite. A bug in the venturi can disrupt the flow and cause a failure to ignite. Low inlet or outlet gas pressure could have the same effect.
This is in respect to a barbeque but the premise is the same
www.barbequeworld.com
This is where the orifices attach
www.repairclinic.com
And this is what the burner should look likewww.repairclinic.com
