I cut out the pretty pictures from travel guides that are mailed to me. How can I stick them to my condo's walls without harming the walls at all?
I lease my condo and my landlord's very strict. I definitely can't glue or tape the pictures to my wall. Some pictures of my walls -
  • ask your landlord about using sewing pins ..... they leave a very tiny hole
    – jsotola
    Mar 8 '19 at 0:42
You need sticky tack
I remember this from when I was a kid and it worked better back then. But it still works great and it's cheap. enter image description herewww.lowes.com
You just use a little ball in each corner and press it into the wall. Simply remove by pulling when you move.
    Sometimes at removal, especially when the tac has been in place for a long time it can want to leave some residue on the wall. You can either rub it off or use a ball of new tac to roll over the spot and soften up the residue and it will come off with the ball.
    – Michael Karas
    Mar 7 '19 at 4:55
    You can also get white tack that is less likely to stain, though I've never had the blue stuff stain either.
    – bdeniker
    Mar 7 '19 at 10:07
  • i've had blue and white both leave behind what looks like grease stains. fwiw, the last pack i bought, manco, seems to work well w/o residue. It actually works a little too well: i've pulled paint and chunks of plaster out of the wall hanging some heavier items (framed pictures, smartphones) with it.
    – dandavis
    Mar 7 '19 at 18:20
What about washi tape? I know you said you can't tape stuff to the walls, but washi tape tends to not be very sticky and makes for pretty decoration, too :) (blue/white tack is definitely also your friend, though, as per the other answer!)
  • Can confirm - bought washi tape for my kids crafts and was very disappointed in how not sticky it was. It would work good to barely stick something to the wall.
    – JPhi1618
    Mar 7 '19 at 22:06
