I just had a new toilet installed. When I flush toilet and the tank fills and fill valve shuts the water off, I hear a dripping sound in the wall for about 15 to 20 seconds. Then it stops until I flush the toilet again and it repeats.
1Are you sure it's in the wall? It could be the drain catching the last bit of overflow. Are you sure it's dripping? It could be a pipe contracting and creaking against the framing.– isherwoodMar 5, 2019 at 13:55
1It could be the fill valve having the last few drops coming out - always challenging the last few drops...– Solar MikeMar 5, 2019 at 14:46
It could be pipe thermal expansion. Is it drip drip or more like tic tic? Tic is thermal expansion.
I had a drip sound like this. Showed up as a small puddle on the basement floor. Turned out the sewer drain had a T installed near landing on the basement steps/side door; an old sink?. Ripped into the plaster and lath wall, and found a piece of 90 year old lead pipe sticking out of the T. The lead had been crushed shut, but decayed over the decades. Cut out about 10 Lbs of lead, and screwed a cover over the remaining end of the T. No more drip. Replacing the lath and plaster hole was hard. Probably should have hired that out. Except it's pretty much a lost art. What I have looks OK, but there's no mistaking it for drywall, or the work of a skilled plasterer.
The lead, cast, is now serving as a couple of nice 5 pound ankle weights.
