My GE washer is an old model (WWA8364VJLWH) and I need to find out how to repair the upper transmission seal on a WH38X39 Transmission.
  • Leaking oil or water? You would need the parts and a repair manual to do the repair. This repair could include taking it completely apart just to get the the transmission, in which case you may want to replace other seals and bearings or brake/clutch system while you are in there. – Jeff Cates Mar 4 at 19:02
