Just had my roof replaced with architectural shingles. Should I be concerned that I can push up the portion of the shingles over hanging the roof edge by about an inch?
  • Are you in a “high wind” zone?
    – Lee Sam
    Mar 3, 2019 at 17:40
  • @LeeSam 110 mph zone
    – Todd
    Mar 3, 2019 at 18:31
    If the shingles were literally just installed, the seal down strips probably haven't had time to fuse together yet. These rely on solar gain to fuse, and a roof done in the middle of the winter is going to take quite a bit longer to "set".
    – Comintern
    Mar 3, 2019 at 23:17
According to GAF Roofing manufacturer’s installation guide, the shingles should overhang the rake between 1/4” and 3/4”.
Here’s their website that explains it better: https://www.gaf.com/en-us/document-library/documents/residentialroofing/shingles/glenwood/glenwood_shingles_application_instructions_english_spanish_french.pdf
Yes, you should be able to push the shingles up about 1”, but if they extend too far beyond the edge of the roof (especially in a high wind area like you live in) they’re more susceptible to blow off.
Also critical is the correct number of nails per shingle. In high wind areas, 6 nails are required.
GAF is a major Roofing manufacturer in the U.S., but I’d check with your shingle manufacturer’s instructions.
  • After waiting for some hot days I can confirm that the shingles are now much tighter.
    – Todd
    Apr 30, 2019 at 19:24
