I have a switch inside my house which feeds power to two fixtures on opposite corners outside. I installed LED motion sensor fixtures which have their own sensors and lights but they have never worked properly. They have the feature where if you turn them off and on with X seconds they should remain on but this never works. Looking at the troubleshooting in the manual it actually says that multiple fixtures can't be on the same circuit. Why is this and how can I work around this problem? Are there fixtures available that support this arrangement? Rewiring the circuit isn't really an option as the switch is on the bottom floor and the fixtures are at the roofline.
Thanks in advance for any answers.
