I want to attach this shower hose attachment to my bathroom tap. It's a two-way system that lets you use the water through the tap or the shower head. Unfortunately the sizes don't match. The hose has M22 and M24 attachments, and the tap thread has a 2cm diameter.
- I've checked all the plumber and bathroom suppliers, and none have any adapters for this.
- I also cannot replace the tap since I'm renting.
- I have also looked into getting a different hose that would fit, and that does not exist either!
So the only option that's coming to my mind is to patch this to make it work somehow. Obviously permanent glue/epoxy is not an option either. So any suggestions or tips would be tremendously appreciated.
This is a similar problem I previously had in another apartment, but now the size and the whole tap is different. Please see the photos there if it helps resolving any ambiguities.
