-1
Put a new t&p valve on my water heater and as soon as it fills up the valve opens why would this happen?
    Hello, and welcome to Home Improvement. What's your water pressure, and at what pressure is the valve designed to let go? – Daniel Griscom Mar 2 '19 at 2:07
Either
  1. The water temperature &/or pressure exceeds the valve's rating (typically 150 psig & 210 F), so it opens
Or
  1. The valve is defective
If your valve is opening the second the water tank fills up, I'm assuming it hasn't had a chance to even start heating the water yet, so it must be from high pressure or a defective valve.
Possibly there's something blocking the valve from sealing, and holding it open. In that case if it were a bit of metal or rock or something it could have damaged the valve's seal / seating surfaces, so I wouldn't trust it even after removing the blockage.
I'd attach a water pressure gauge somewhere and see what your water pressure is, and just exchange the valve for a new one.
|improve this answer|||||
It could be pressure is too high or possibly the wrong type of valve. Most t/p valves have a long rod sticking out. The rod is the temperature sensitive component. Check the rating of the valve. Make sure it's not 30psi. A picture would be helpful.
