A wire in my garage got damaged. Breaker is off now. The wire feeds the stove on the other side of a split level home. It is an old cloth covered wire, with no ground. Red, white, and black wires only.
I am going to get my brother (power company senior tech) to assist me in a solution, but want to get my head around it before breaking it to him.
The plan: The wire coming from the panel box is just too short to tie back into. I want to run a length of 6/3 cable (w/ ground) to an exposed 4-11/16 x 2-1/8 square junction box mounted in the ceiling (joist). Bring the new cable and old still running to the stove wire into the box. Use 3 appropriate Polaris connectors to complete the circuit.
My question....what do I do with the ground wire on the cable? The box should be grounded, yes? Can/should I ground the box? Would doing so be a code violation? What is the best solution other than the impossible task of running cable all the way to my kitchen?
