Can an indoor Transfer Switch be used on the other side of the wall as an outdoor service entrance and main panel?
The concept is: The outdoor service entrance is wired through the wall to the SE rated indoor transfer switch. Then wired through the wall again from the transfer switch to the outdoor main panel. Is this ok or will I need a UL listed panel to keep outside
