The pantry door in my kitchen is a hollow-core door. There's quite a lot of wasted space between the door and the existing shelves, that I'd like to utilize by hanging full-width, full-height, 8"-10' shelves on the inside surface of the door.
The plans I've worked up suggest that the shelves, when full, would be supporting quite a bit of weight, and I'm concerned that the hollow-core door won't be able to support it adequately.
How difficult is it to replace one door with another using the existing frame/jams, etc. It seems pretty straight-forward, but something tells me that there's more to it than I imagine...
Is this something that is worth doing, or is it a rabbit-hole of pain and disappointment?
