I'm trying to figure out the safest way to hang a 100lb heavy bag from the ceiling in my garage.
The pictured part is under a bedroom, and the continuous line, if it's like the part that is under the attic has a 1.5inch wide piece of wood. The other half of the garage does not have any of the perpendicular beams.
From what I've read, I can't just hang it with a single eye bolt, and I don't have access to the other side because of the room above. I found this TuffRail system, but I'm not convinced that it would be structurally sound. I also found this SpiderMount, but the spacing of the larger beams doesn't match.
Is it possible to safely hang the bag?
