I have no lights in my bathroom and have two receptacles and the light in my bedroom that don't work. I replaced the gfci in my bathroom and it works, i have reset it too. The light in my closet works. The other outlets in my bathroom work.
    Do you know if all these lights and receptacles are on the same circuit? – ThreePhaseEel Feb 24 '19 at 22:39
    Did it all work before you replaced the GFCI? – Harper - Reinstate Monica Feb 24 '19 at 23:26
  • Did you wire the GFCI properly? Load vs line? – Jeff Cates Feb 25 '19 at 12:47
  • What is the age of your house? – Retired Master Electrician Feb 25 '19 at 13:19
  • Threephase, i do not know if they are, but how would I check to find out? Harper, no they didn't, one day it all just stopped, gfci did keep tripping and wouldn't reset. Jeff, I think i did, i have a tester, the lights lit up with the reading that it was, i plugged a lamp into it and it worked, i hit the reset button and it worked. – Kelly Arthur Feb 25 '19 at 13:29
