My GE dishwasher won’t drain. Washer is washing, but doesn’t drain. Ending the washing cycle, there’s not hum.
    Hello, and welcome to Home Improvement. Any reason why you aren't guessing that the pump is bad? – Daniel Griscom Feb 24 at 18:29
  • I couldn't find info on the model number you listed. Could you double check it? Also, some machines have separate drain pumps, and others use a switch that reverses the wash pump to allow for draining. The switch or pump could be bad, even the timer itself could be bad. Lots of could be's. – Jeff Cates Feb 25 at 6:10
