Our new home has a kitchen in a corner without a vent-out channel.
As far as I understand, standard kitchen hoods can't condensate and collect water from the air they process.
What can be an alternative to dry the air during cooking?
  • Can always crack an outside door or window a few inches Commented Feb 24, 2019 at 16:38
  • In this case depending on the weather I have no certainty how much moisture has the chance to suck into the ceiling.
    – J. Doe
    Commented Feb 24, 2019 at 17:09
  • What is the age of the home? If built in the last 30 years the exhaust vent would be required to vent outside the structure. If you have a range hood it should vent to the exterior of the building, more information on why you think a "vent channel" is not there or how the corner kitchen is the problem.
    Commented Feb 25, 2019 at 5:51
How about using a small kitchen dehumidifier?
